moonpie33's 1985 Pickup Build-Up Thread
hey guys
well i have started my build
i have a ton of plans
the truck should be getting a paintjob this week or next, all by me. So i have a 85 supra also but she has a 7m in her and i needed somthing to put the 5mge i just built into.
the 5mge has 199 hp and 203 TQ at the crank! stock is 150ish this aint stock though this was on a motor dyno also
the mods on the motor include
OS valves
bored 30 over
knife edeged crank
gude cams
camry alt upgraded alt basically
timing was 15 degrees BTDC and more then 20 on the dizzy
i had to run 93 to avoid pinging
never knocked or pinged under load
and a few other fun things
this is a rev monster this will be a great replacement over the sad little 22re
so i found this truck, shes in terriable shape so ill give her a new life
let the fun begin
here is a teaser pics more pics will follow
OS valves
bored 30 over
knife edeged crank
gude cams
let the fun begin
The truck is completly stripped down now new pics in the morning casue im
to tired to upload them
also UPDATE the bed is soo rusted out it cant be used
soooooo flatbed here we come
kinda sad cause i like long beds O WELL
the new color will be gloss white
i picked up the paint so just doing the prep work curently
after the paint job the 5m goes in then iill wire her up and get her running
then move on to the suspension and breaks etc..........
cool looks like a cool project
if you are going to go flatbed than i would check this out half way down the page posted by yotamonster. best looking imo https://www.yotatech.com/forums/f116...6/index97.html
so today i pulled the drag link bar off and ordered a rebuild kit.
then i took the steering arm off and accidently dropped a washer in the little hole so above the steering arm so now i need to pull the whole front driver side wheel assembly off and redo it grrrrrrrrrrrrrr
so im hopeing to have it painted this week
thanks
well update truck cab is completly sanded down
im going to be buying the paint
im really considering gloss white
after the paint its smoooth sailing
also pulling the front axel
shes going to get a check up
anyone know if there is a online tsrm
i need to see what the preload specs are
so i wont be using the cab now
i found an 86 truck only RWD that i plan to use
it will give me a little extra room
i still plan to run bucket seats though
pics to come very soon
cab will be off tomorrow
06-01-2021 01:51 PM
