fs-1980 shortbed
fs-1980 shortbed
it is a 1980 short bed
-20r (112k i believe) engine leaks oil i believe it is the oil pan and valve cover gasket, the alternator wiring went bad so he has a chevy alt wired in that works
-tranny grinds in 1st 2nd and 3rd and clutch is in need of replacing
-the body(original sheetmetal) is in good shape, the only rust holes that i am aware of are on the tail gate, bed is solid and pretty sure the cab is because i was under there 2 years ago when he changed the tranny, the truck is half primered he lost interest in it and he never has money....the drivers door has alot on surface rust but nothing a nice sanding wont fix
-the interior would probably be where the most work is i know it needs door panels and the drivers side window is off the track, i am unsure about the dash as it has had a cover on it since he bought it
he has owned the truck for the last 6 or 7years and before that it was in colorado on a air base....
*spare parts*
solid front axle, grill, headlight bezels, set of tail lights, 2 carbs, 2 trannys and t-cases, fan, box of power steering parts, he said there is a/c stuff also and any other toyota parts that are in his garage, there maybe more im not sure ill check when i go take pix soon
he wants 2800 for it without the 33 but the wheels will go with if u want its your choice and he will find some tires to put on it.....and if the price is right the 33s will go with the are less then a year old and have maybe a 1000miles so basicly no wear on them and those were 160 a tire new
this is located in omaha nebraska
*spare parts*
Mike Maiato
08-28-2015 02:35 AM
Badfish740
08-27-2015 06:38 AM
gtpunk18
05-21-2007 01:09 PM
white_n_slow
09-14-2006 08:39 PM
