Which other car wheels fit 89 2wd pickup?
So I've tried searching the forum and it has been increasingly difficult to find much information regarding the 2wd 5-spoke model. I recently purchased the Toyota truck for a deal i could not let down. The main use is going out to the mojave for camping trips. That said i am looking to lift it to give it some ground clearance (larger wheels would probably be fine) and perhaps a body lift to add cosmetics. I am looking to change out the wheels on the cheap so i am wondering if there are any other car models out there that have a similar pattern as the 5-spoke 2wd 89' yota? The 03' F150 looked similar but i'm not sure... I'm sure many of you have dealt with the same problem and so i am looking for advise. Thank you
Try posting in the 2wd forum. The bolt pattern is 5x4.5, so anything with that will work. Off the top of my head, pretty sure most jeeps and rangers share the same wheel.
Nice, i was also curious to see what it would look like. Anyone out there have the 2wd model with just larger tires? I believe my vehicle right now has 14'' rims and small tires. I'm really not into that lowrider look.
97-06 Jeep Wrangler/Cherokee wheels fit. It's pretty common. I've had them on my 92 2wd pickup with 215/75-15 tires on it stock.
The 15s I have on my 84 2wd fit both my sister current Jeep XJ and former Jeep KJ and they are both 5 spoke.
As for pictures of 2wd trucks with bigger tires here is my 84 with 30x9.5x15s on the rear and 215/75R15s on the front with cheap steel wheels.
So I've tried searching the forum and it has been increasingly difficult to find much information regarding the 2wd 5-spoke model. I recently purchased the Toyota truck for a deal i could not let down. The main use is going out to the mojave for camping trips. That said i am 30000k hid kit to lift it to give it some ground clearance (larger wheels would probably be fine) and perhaps a body lift to add cosmetics. I am looking to change out the wheels on the cheap so i am wondering if there are any other car models out there that have a similar pattern as the 5-spoke 2wd 89' yota? The 03' F150 looked similar but i'm not sure... I'm sure many of you have dealt with the same problem and so i am looking for advise. Thank you
aciorba23
06-29-2015 04:18 PM
AUJWE
7
07-11-2002 09:46 AM
