New tires on stock rims?
One of my neighbors does scrap metal work and hauls cars all the time and came across a set of nearly brand new BF Goodrich A/T Baja Champion 31x10.50 R15 and i was actually curious to know if these would fit my stock rims? He's offering to give them to me which of course i accepted but i'm struggling to find some good used 15 inch rims for under 200 dollars. Not a very big budget but i've come across them for that cheap on craigslist before so I know if i wait, i can get them for that.
So I was wondering, would these tires fit my stock rims? From my inspections they should, but i thought i'd ask before i put any effort into it. I'd hate to not have my stock tires to put back on for fuel efficiency but I guess i can go without for a while until i come across a cheap set of rims on craigslist.
If they do fit, how hard is it to switch these myself?
Thanks in advance for any help.
I run those same tires. I was told that they would fit the stock 15x7 rims on our toyota's but I ordered a set of 15x8 so it won't look so narrow vs 15x7. If you don't care about using stock toyota rims you can always order a set of steel wheels, mine were $40 ea brand new at summit racing. 15x8 cragar soft 8.
They will fit fine. I run 33x10.50s on stock 15x6 rims and they work great:
- http://www.4crawler.com/4x4/BFG_AT_KO.shtml
Only problem you may run into is finding a shop to mount them for you. Typically a 15x8 rim is the minimum recommended for that size tire and some shops won't go narrower. May have to search around for a shop that will just do what you want. I now mount my own tires, so don't have to mess around with the shops.
Thanks for the help.
I run my 31x10.50x15 all terrains on my stock 15x7 rims, and they look and feel fine. They were mounted by Americas/Discount Tires, so I'm sure you could find someone who will mount them...money talks
Thanks. Yeah I might end up having to do that. I searched for the Cragar soft 8 but was only able to find them in 5 bolt patterns. =/ Would love to have a set if they came in the 6 bolt.
They're the 6x5.5 bolt pattern so they fit on toyota's. The -12mm offset makes the tires stick outside the fenders about an inch but that's the look I was going for, if you don't want that then get one with a more positive offset. Checkout the D window style too, you might like that one.
This what I ordered from summit:
http://store.summitracing.com/partde...5&autoview=sku
Cragar “Soft 8” 15x8 Wheel (Series 397, PART # CRR-3975860, Backspacing is 4”, offset is -12mm), U.S. Wheel Chrome Center Cap (PART # USW-C425-P, 4.280” Diameter), Summit Racing Equipment Acorn Black Chrome Lug Nuts (PART # SUM-754001B, 12x1.5mm Closed End), Gorilla Acorn Black Chrome Wheel Locks (Part # 71631NBC).
Ah ok. Yeah I think i'll like them sticking out a little also. For some reason when I searched those didn't pop up. I'm creating a shortcut and will probably place an order on friday after I get paid.
Thanks again.
Thanks again.
Is your avatar photo your truck? I think that the Toyota stock alloy wheels are 15x8....Most steelies are 15x7, but some where 15x8. I could be wrong, though..
How do you figure out how much offset? I'm not interested in having mine stick out at all..
Ok, I see.
Now, is offset and backspacing the same thing? They are listed as offset of -12mm, backspacing of 4"..
I know my truck needs 3" or less backspacing. That's easy to order, but I don't know anything about offset..
06-01-2021 01:51 PM
coffey50
07-28-2015 10:55 AM
