Need help choosing tire size please
So I just ordered Toytech lift for my 96 4x4 Tacoma. Everything is basically stock. after installing my lift i will be looking for tires. any advise on what size to get? he is the lift i ordered,
http://www.toyteclifts.com/index.php...mart&Itemid=72
Kinda new at this any help will be appreciated =)
thanks,
-Joe
thanks,
-Joe
You'll find some general tire size vs. lift information for the Tacoma below:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
oh cool, yeah the front is a 3" and the rear is a 2". The tire chart that 4crawler showed me said that the front would fit a 33x9.50, but im not to sure if this size will fit on the back.
Usually if a tire fits up front, it'll fit in the back just as well. Why? Front tires move up and down with the suspension, but they also have this nasty habit of turning side to side as you steer. And since the tire sits outboard of the steering knuckle pivot point, it sweeps out an arc while turning side-side. So you need more room to fit that sort of tire inside the wheel well that the rear tires that just move up and down only.
A tire that many people people run with those type of lifts is 265/75/16, this tire fills out the wheel-well fairly well. If you want an even better tire with that lift you can squeeze in 285/75/16 (roughly 33's). Im running these on my truck, and only have slight rubbing at full lock.
oh, since you have 15" wheels you will not be able to run the 285 tire becuase it is not available for the 15" rim. The 265/75/15 tire is available but you won't have to much to choose from. So you best option would either be a 32x11.50R15 tire (which is 11.5 inches wide and 32 inches tall) or a 33x11.50R15
djpg2000
11-11-2020 04:56 AM
Luvmeye22re
08-04-2015 03:53 PM
coffey50
07-28-2015 10:55 AM
