custom xover fit issues
Old 03-09-2011, 06:01 PM
murphyz's Avatar
i did a custom homemade xover and when i bolted it up and mated the engine to teh tranny... The flange that connects to the xover now is too close to the torsion bar, and I am unable to put the heat shield back on... can i shave that flange bolt material closest to the torsion bar? do i need the heat shield?
Old 03-09-2011, 06:06 PM
dntsdad's Avatar
Post up some pictures
Old 03-09-2011, 06:11 PM
murphyz's Avatar
the heat shield next to the engine stand
this flange
Old 03-09-2011, 07:11 PM
dntsdad's Avatar
I think that you could grind that flange. I did a little on mine. I would think that you would be OK so long as you do not get too close to the bolt holes/studs (I replaced my studs with nuts and bolts) and where the seal donut will go.
Also, I have not been running my heat shield since the swap. Has not burned down yet.
Old 03-10-2011, 02:53 AM
murphyz's Avatar
thank you i will be doing the same then
Old 03-14-2011, 01:13 PM
hamish_18's Avatar
x2 on the no heat shield. the rubber boot on the torsion bar hasn't melted off either
Old 03-14-2011, 01:44 PM
yotarob2005's Avatar
I think that we can try to bend it alittle bit. I'll grab a pipe that fits nicely inside the exhaust and we'll see if we can get it to move, only needs 1/2" or so.
icentropy
09-16-2020 02:47 PM
tj884Rdlx
08-28-2015 12:04 PM
rondogracing
Engine Swaps
16
08-24-2015 03:02 AM
MTLroadierunner
07-20-2015 03:07 PM
icentropy
07-09-2015 02:12 PM
Quick Reply: custom xover fit issues
