custom xover fit issues
i did a custom homemade xover and when i bolted it up and mated the engine to teh tranny... The flange that connects to the xover now is too close to the torsion bar, and I am unable to put the heat shield back on... can i shave that flange bolt material closest to the torsion bar? do i need the heat shield?
Post up some pictures
http://i683.photobucket.com/albums/v...r/100_3090.jpg
the heat shield next to the engine stand and this flange http://i762.photobucket.com/albums/x...y/DSCN5968.jpg |
I think that you could grind that flange. I did a little on mine. I would think that you would be OK so long as you do not get too close to the bolt holes/studs (I replaced my studs with nuts and bolts) and where the seal donut will go.
Also, I have not been running my heat shield since the swap. Has not burned down yet. |
thank you i will be doing the same then
x2 on the no heat shield. the rubber boot on the torsion bar hasn't melted off either :)
I think that we can try to bend it alittle bit. I'll grab a pipe that fits nicely inside the exhaust and we'll see if we can get it to move, only needs 1/2" or so.
