1995 P/UP SAS BUILD UP Your Advice Please
Here is where I need an opinion or two.
I am using stock shackles with TG 3" leafs. How do the angles look?
I haven't tacked the bumper yet. As it sits in these pictures, the front hanger is sitting about 1/8 inch inside.
Any and all feedback is welcome....
DROOPED
This one looks like the shackle is touching the frame... just a bad angle from the camera. Actually has about 1/4 inch before touching the spring to the frame.
UNDER TRUCKS WEIGHT
DROOPED
UNDER TRUCKS WEIGHT
#26
I thought that was compressed? It was completely off of the driver side jack stand in the last picture. Unless the passenger side jack stand is holding a little weight?
#28
Thanks.... I am sure a little questionable about it. I moved the hanger in to about 1/2 inch and that seemed to help a little but I think that is moved in to much. I certainly don't wanna have any clearence problems with the steering..
I'll put the axle under it in the a.m. if the rain doesn't come in too early.
#29
The pictures with it under weight didn't load up for me the first time. The angles look good to me. I noticed on mine that the shackles settled a little farther back when everything was in and I drove it compared to how they looked when I compressed them with the floor jack so keep that in mind. Did you install the Half inch spacer on the driver side spring perch?
#30
Post lots of pic's of the fabricated ARB bumper, please and thank-you!
#31
According to your experience, I probably shouldn't move the front hanger back any more... I moved it in to about 1/4 in. to 3/8 last night just to look at the angle difference.
Not that significant, so I will probably go with what has been shown here.
By the way, are you running 3" spgs?
Thanks....
#32
Yep, me to. I am not real sure about the future of ARB.... may come out looking like a gremlin spoiler.....ha!
#33
Ya, I wouldn't be moving the hanger any further back either. Im running the 5" springs. I wouldn't put the spring pad spacer on there either if I were you. According to my personal experience and a few other guys I have talked to with on here it is not needed and makes the driver side sit higher. I had to put another spacer on my passenger side to level the front out since it was sitting 1/2" lover than the driver. Just my .02
#34
I am hoping the spring pad doesn't kick me in the NUTZ as far as height, but if it does I will let you know. I mean, afterall, what's a little more torqueing and grinding...
I have decided to mount the hanger flush and see how much these springs "settle". I keep reading (your post & others) that they settle anywhere from 1/2" - 1".
If they settle 1/2" i will be sitting nice...
I am debating what kind of set up to go w/ in the rear. I have sworn on an ARB air locker but I keep hearing/reading good things about the aussie locker. Big difference in $$$$$... that's what is causing my dilemma (I'm a tight wad)
The truck will be a farm/hunting truck as well as a daily driver...
Any thoughts?
#35
Well, got the TG 3in leaf springs mounted w/ the axle (stock shackles). Little to high for my liking.... so, I am waiting on some Ole Man Emu front leaf springs to lower it to my liking.
I'll post some pics later....
#36
One thing... as mentioned, the ride height is to high for what I am trying to accomplish. However, I do have a question about the wheel spacers. My wheels, once installed, have about 1/4 in of stud thread that protrudes through the wheel for the nuts. I am thinking I have some really thick wheels, but they are factory. Is this normal?
#37
Put the bumper back on. Well, partly, I am trying to figure out how to put some more bracing on it due to the front spring hanger placement. I had to cut off some of the support plates to get it to fit.
#38
Well,
Finally got part 1 of 2 packages from MC...
This thing is tiny
Installed the compressor
And finally got the switches wired in and mounted
Installed, after I did a little grinding to make the diff fit inside the housing ... I still have to get the air hose tucked a way a little better...
and a shot from the rear....
This thing is tiny
#39
ARB is mounted and ready to roll... Just waiting on my OME front springs and all the "big" stuff is done...
I am going for this amount of ground clearence...
#40
waiting on springs, wheels, and the michelins to wear down so I can put some 33's on this thing. I say about 40,000 more miles... or I get an itchy finger and go ahead and buy new tires... probably the later...
