Switching 22r to 22re
you would need to either swap the wiring harness or add the required wiring for the computer and EFI and related sensors to work. It can be done, a few people here have done it.
i think that you would just have to put in a new fuel pump in the tank if it would fit. if not then yes you would. because a carb takes about 7-10 psi at the most to run a efi has to have 35-40 psi to start
