Semi truck air tank for OBA
First off, hello everyone! I've been lurking this site for awhile now and learned a great deal just from searching around and poking through the various threads here.
I'm currently in the middle of setting up an on-board air system on my 4runner and was looking for an air tank but was wondering if anyone has ever used the tank out of a semi's air brake system for their system? It seems like these tanks can be had, used, for cheap but I cant find any information on pressure ratings or port sizes for them. I would assume they are all DOT or SAE J10 compliant but cant figure out what pressure they would be rated to.
I found some aluminum ones, used, for cheap and was going to call and see if I can get more info about them. http://www.acmeequip.com/detailview....vendor=5470674
I'm planning on running my system at 150 PSI so I'm mostly worried about the pressure ratings on these tanks. Am I smoking crack or is there any reason you can think of that one of these wouldn't work?
If you're looking to spend close to $70 on a used aluminum tank, why not get one that's new and freshly rate for $10 more - ebay has aluminum air ride tanks for right around $80
Aluminum doesn't rust
looks like that semi tank is close to 8.5-9 gallon? Based on it's dimensions. Those $80 ones on ebay are 5 gallon. Maybe he's looking at the size of the tank as well?
Thank you for all the replies, I'm going to call these guys on Monday when they are open, and see if I can get some more info about them.
Mahogany
08-12-2019 01:31 PM
bigblue82
10
07-06-2015 08:27 AM
Eagle564
06-23-2015 11:29 PM
saphirekosmos
06-22-2015 10:26 AM
