Okay everyone let's see some pics of your system...
#41
Actually i built the box within specs for that particular sub these are the sealed box dimensions reccomended from that sub
"Min Rec Sealed Box Volume (CU. FT., Liters) 2.25, 63.7
Max Rec Sealed Box Volume (CU. FT., Liters) 5.0, 141.6"
Built close to 3 cu. feet so maybe do some research before you say my system is ghetto it's the best one ive ever seen or heard of in an 84 pickup.
Edit: it's wide but only 9" at the top and 11" at the bottom
#42
Check your math - judging from 10's on the top, a 12 on the front and ~48" wide, you're closer to 4 cuft (admittedly, within JBL's barn door size specs)
I had 2 10's in the same space - only difference was mine was an '89 (pix in post 23)
#43
Maybe it was more than 3 i dont remember but it definitely wasnt's over 5
btw, ported are generally a lot smaller if i put square ports on the sides it would be sufficient for two 12's but i like the deep sound the large sealed box gives you and dont need two subs.. i'm not into pumpin massive bass or anything
#48
1 15" fi btl sub woofer
3000 watts RMS
67 lbs.
Dual 2 ohm voice coils
Magnet is around eleven and a half inches in diameter.
Cost around $450 Smackaroos
And 0/1 Gauge wiring.
This image has been resized. Click this bar to view the full image. The original image is sized 800x600.
3000 watts RMS
67 lbs.
#49
Location: Yotatech, because Pirate is too expensive. NorCal.
This is a direct quote from the User Manual for your JBL Sub (if its the GT5-12)...
"An optimum vented enclosure is always larger than the optimum sealed box for the same woofer and will require more space inside the vehicle."
Here is the link to the manual it is on page 2.
The specs JBL recommends for the GT5-12 are...
Sealed: 1 ft^3
Vented: 1.75 ft^3
Bandpass: 2.25 ft^3 (all together)
#51
I thought your enclosure looked a little big for the sub. You might want to check it. If it is to big you can damage the sub. Not enough pressure and it will move to far.
WTB[PacNorWest]: 84 4Runner brake booster/brake master cylinder
user 82300
09-17-2015 10:41 AM
FS[SouthEast]: Brand new 26 mm. Downey torsion bars
HiLuxer
09-09-2015 02:43 PM
