Grinding in front HELP!!
While 4wheelin this weekend a grinding noise began in the front end. It happens when you let of the gas and coast. The closest I can compare it too is when the abs engages, the same high vibration. There is also infrequent vibration at speed when the hubs are locked, goes away when unlocked. Any ideas would be apreciated.
Thanks
Thanks
Spindle bushings are a likely culprit, I think there is a needle bearing replacement for them:
http://www.4x4wire.com/toyota/maintenance/front_end/
Shaun Crystal Gomban
07-30-2015 10:13 PM
mengquis
07-13-2015 10:39 AM
