Cool Center Cap Idea *pics*
Well i got my new rims and have been looking at center caps and dont like what i have found very much and then i remembered the center caps on my old rims and wanted to see how they would look but i have one problem...
How the heck am i going to make them stay???
Any ideas?? i think it looks better than any other center cap out there
here are some pics:
front:
Rear:
here are some pics:
front:
Rear:
Take out the circular metal ring, extend the tabs ( how?, not sure, solder, rivet, make complete new ring) anyway make the new tabs long enough to bend out and drill them to fit over the lugs and then bolt them down with the tire lugs. Of course the new tabs with have to be in behind the plastic tabs on there. Not sure if it will work but it's the only idea I can offer.
Derek
Derek
buy the metal crome ones that come with all kinds of rims. cut them down to size or keep them the same size so the out side diameter of the new ones fit inside the old ones. Trim all the tabs off your center caps and j/b weld or pop rivet them on
Well unfortunately i just sold the rims and center caps for $200 so it will be a while when i get some more but when i do ill find a way to put them on
but keep posting ideas cause i will get to it eventually
Derek
Derek
yeah i like your idea maybe rivet some sheet metal to the tabs and bend the sheet metal at 90 degrees and bolt them down between the rim and the axel???
jb weld some magnets out of an old hard drive on both cap and hub, that way you can just pull it off when you need.
those magnets are SUPER tuff, that thing wont go anywhere.
i like that idea and i could see how it would work for the back but how would it work for the front??
FS[PacNorWest]: Factory Alloy Wheels - Bay area
94whiterunner
9
09-22-2015 07:28 PM
Poncho0206
07-10-2015 06:21 PM
