Best way to remove por 15 type rust paint from skin??????
Old 08-13-2009, 05:54 AM
swerks's Avatar
I think you can guess what I did !
Old 08-13-2009, 06:47 AM
4Crawler's Avatar
If it has not cured, naptha or lacquer thinner will work. After it cures, about a week and the outer skin layer will wear away and the paint with it. Sometimes, you might be able to use a petroleum jelly and rub it into the area and it may help lift up the paint.
Old 08-13-2009, 07:07 AM
tc
tc's Avatar
Herculiner on your hootus? ( if you haven't seen it)
x2 for what Roger said - if it has dried, you're pretty much waiting to get rid of that skin.
Old 08-13-2009, 07:19 AM
ozziesironmanoffroad's Avatar
next time wear rubber gloves.... .
x2 on the thinners...
Old 08-13-2009, 07:22 AM
4Crawler's Avatar
I've even had that stuff get past 2 pair of rubber gloves!
Old 08-13-2009, 07:23 AM
are you kidding?! holy moley! strong stuff...
Old 08-13-2009, 08:55 AM
JasonWin's Avatar
I'd use ABS Pipe cleaner, but I'm asumeing you're not a plumber and don't have it readily avalible.
Old 08-13-2009, 09:45 AM
tc
tc's Avatar
It reacts to the iron in your blood/skin. If it's dried, it doesn't matter what you use (unless that stuff happens to burn off the skin, but that has other issues!)
Old 08-13-2009, 09:48 AM
ha... the old draino....
'WARNING: DO NOT ALLOW CONTACT WITH SKIN!'
Old 08-13-2009, 10:52 AM
eighty5yota's Avatar
? try some sandpaper to wear it down as much as possible.. like a nail file from the old ladies side of the sink...
it might get brittle and crack off better?
Old 08-13-2009, 10:58 AM
Lumpy's Avatar
Brillo pads, palm sander or you can just remove that part that you got it on . They make new hands now...Some of them are really nice.
icentropy
09-16-2020 02:47 PM
chukarhunt
12-08-2019 11:39 AM
09-04-2015 09:27 AM
TJWilly
07-31-2015 02:05 PM
Quick Reply: Best way to remove por 15 type rust paint from skin??????
