Tips & Tricks Tips and tricks to make the site easier to use such as posting pictures, where to host them, and avatars
1984 4x4 won't shift to 4wd ????
Old 03-27-2015, 08:12 AM
optimumpear420's Avatar
I have a pickup that won't shift out of 2wd any suggestions would be very helpful
optimumpear420 is offline
Old 03-27-2015, 09:38 AM
millball's Avatar
Is the truck new to you?
If not, have you ever been able to shift the transfer case in the past??
Removal of the shifter and examination of the shifting rails and shifter bottom button might be enlightning.
millball is offline
Old 03-27-2015, 09:45 AM
Yes its new to me but IT has been in the family with one owner and he said when he parked it that it worked but I have never shifted it someone said there is a spring that might not be working right but I don't know where this spring is even located ????
Old 03-27-2015, 11:58 AM
millball's Avatar
The factory Service manual knows all.
millball is offline
Old 03-27-2015, 12:12 PM
Unfortunately I don't have that
Old 03-27-2015, 12:44 PM
millball's Avatar
Here is a link to the 1985 FSM.
Your truck should be similar. --
http://www.precision4wheeldrive.com/1985FSM.pdf
Takes a while to load.
Might look here as well--
http://web.archive.org/web/201209012...fsm/index.html
millball is offline
Old 03-28-2015, 03:58 AM
Thank you for that link , I didn't even think of that, people like you are the reason I got this app thanks millball
Old 03-28-2015, 01:58 PM
shadowbirdie's Avatar
The FSM is great,
The FSM is great, but I don't think it recognizes aftermarket issues like
a 3 inch BL which is affecting my TC shifting, other resources cover the slack though...
J
shadowbirdie is offline
Old 04-26-2017, 10:10 PM
kjjk56's Avatar
Does this Pickup have the AISIN 4x4 Locking Hub Dial? Or is it not shifting in the transfer case? The Locking Hub Dial has a spring that goes in and out depending on freewheel of locked wheels to the axel.. check the front tires
kjjk56 is offline
mskalmus
05-28-2017 07:51 AM
Tykiller1994
08-10-2015 07:49 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
hangtown88toy
07-10-2015 02:33 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: 1984 4x4 won't shift to 4wd ????
