wheel felll off and lug holes on aluminum rims are elongated
hey there i bought i set of eagle alloy rims on 33's l last week aand istill have to get thembalanced.so a tirefalls off and rolls past me last night. i put the wheel back on the truck and i see the lug holes are oval shaped. i can still centre the rim with the tapered lug nuts but can the tire stil be balanced? i will have to get taped on wheelweights. thanks
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I thought all new aluminum rims required a periodic re-torquing so the sleeves can get tamped down...
Vary common problem. If aluminum...
That and "knock off" spindles reversed so torquing spins them off, instead of tightening ask me how I know... No don't!
Your balancer guy will tell you if it's warped or not...
If it comes up to like 10oz. that's a TON in wheel weights, and it's warped...
And they make clip-ons for aluminum too, and you can set a balancer to only put them on the inside.
And yeah, x2 on 2door4runners post... "i can still centre the rim with the tapered lug nuts" Makes me think your using your original lugs...
See SR5 lugs. They're made to go into the lug hole.
You should just replace it as it is not worth an accident. That happened to me a few years ago when a buddy was helping me put the wheels back on my Altima. I assumed that he had tightened and centered the wheel properly. The wheel was toast and I could not find the discontinued style anymore. That really sucked but lesson learned. Double check your buddys work.
06-01-2021 01:51 PM
