want start when warm
I have a 82 pickup with 22r and i can go outside right now and it will start right up. But if i go for a ride like to the store it want start back up until it cools a little bit. Any suggestions.
Thanks
Thanks
For an '83, check your Hot Idle Compensator (HIC) on the carburetor.
Check to see if the carburetor is flooded after shutdown. It is common for the carburetors to leak fuel into the intake manifold and cause a no-start. If so, Toyota says to floor the gas pedal and hold it there until the engine starts.
Another way to see if the carb leaks is by checking the fuel level in the sight glass.
Kluch8651
07-09-2015 10:39 AM
