Truck won't start
Truck won't start
I just replaced the fuel filter and fuel pump on my 94' Toyota pickup and now it won't start. Can you help with what the problem could be?
yes we did. It's running but when I step on the gas it sputters and wants to die. Could it be the air flow sensor? It was doing this before we replaced everything too.
So far I have replaced the water pump, fan clutch, v-belt, fuel filter and fuel pump. But it was sputtering before we replaced the filter and the pump.
I would check all your sensors first. Mine was doing the same thing and I replaced the air flow sensor and I was good to go. If that doesnt do it then I would move on to the timing and make sure that it is all squared away.
Cesarl74
04-23-2016 06:07 PM
