TPS not hooked up
TPS not hooked up
i was having a problem with my tps and could not get the runner to run right with the tps hook up so i decided to see what would happen if i UN hook it and the runner runs agian is this a problem and why should i set the timing and idl to mach or fix the tps
Wow, another TPS thread.
There has been a flood of these in the past few days.
If what Roger posted is not what you're looking for or doesn't help you for some reason, please use the "Search" feature and I guarantee you'll find results.
Thank you for posting this in the correct section though, I appreciate that.
Good luck,
Fink
Good luck,
Fink
thank you all for your input i will go do a lot of resurch i was welling the ather day and came a croes a prety disent hill climb and tryded twice and culd not make it i would have ben allright with that but wen thare are two fords in front of me i just culd not let it go need les to say i finly made it but i was in 1st gear 4low and losing power!!! need to get it running right
smilen724
13
11-08-2015 04:11 PM
