timing without removing chain cover
Question! 22r toyota 4runner efi. cam bolt backed out and timing gear came off. motor has jumped time and probly bent a few valves. is it possible to retime motor after my new head is instaled without removing timing chain cover. motor is in truck.
If you're re-using the old chain then of course you can keep the cover on.
The big question is WHY do you want to? It takes like 5 minutes to remove the timing cover. Might as well replace the whole timing assembly while you have it apart.
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
