stock yota needs new tires.... advice
ok stock 93 yota and im going to invest in a set or tires... ideally i would love 33... i know i can fit 31.10.50.r15 no problem...but if im going to spend 800 bucks should i get what i really want??? do you think i could fit 32 or 33 on?? probably not in a 12.50???? so maybe in a 10.50?? i can do some pounding and I want to do a 1 inch body lift buy its winter and i could use tires like soon....would you keep on saving and get a body lift and the tires you want... or would you get the 31.10.50 and not have to worry about the tires not fitting.... is a 31 inch tire too small for offroading?? im basicially going to keep the ifs..... add some bj spackers and a 1 inch lift.... should i save get the spacers and lift b4 the rubber??? basically i want advice on what you did and what you would do if you had to start building you rig again from scratch ...
MTLroadierunner
07-20-2015 03:07 PM
Iceman4193
07-15-2015 04:48 PM
