Problems with 33s and 3in lift? 3rd gen runner
I have almost everything to do a 3in lift on my Runner, its a 99 SR5 with 217xxx miles on it. I really want some 33x10.5 15 tires after I get the lift, but I'm worried about that age of the suspicion components and drive ability since its my DD. Any one had any problems or for see any for me? I have 31s right now. Gas mileage I know will suffer but thats a given and I'm ok with that. I have already replaced the lower ball joints on both sides.
I wouldn't worry about it, and I also wouldn't go 3" to fit 33x10.5. I got about 1.75" of lift up front and clear 33x10.5's excellently. With 3" of lift your going to run into cv problems.
Well I already have (almost) everything for the lift, I got OME rear springs and was going to get 2.5in daystar front spacers, and I have a dif drop already, so the cv angles should be alright. If I get new tires they will prob be BFG ATs again. Its either 33s soon or wait till mine wear out and get something bigger.
Another question, re gear for 33s? If so what ratio?
I'm running 285's with 4.88 gears and its just enough gearing. In my opinion, for your money, you shoud go at least 4.88's. Some runners and tacos come with 4.56 gearing. At 60 miles per hour my rpm's are at 2000. If I could do it again I would go 5.13 gears but mine is not a daily driver. I'm down to 16 mpg with all my mods.
I use a revtek lift it seemed to be the highest lift more like a true 3" lift. Plus I have the original CV joints and finally have the boot on the passenger side giving out. CV's shouldn't be a problem. Also the stock gears are fine. That's why there is a low side
you're cv's should be fine and the gearing, if anything, 4.56 will suite it well. Stockers will be ok though. The only thing I would be worried about with 33's is rubbing on the UCA cus there wont be much room. IF that happens about a 1" - 1.25" spacer will be a must.
that 3" will be fine. Even with diff drop though, imo the cv's are in terrible angle but it should be fine. Like you already know, fuel mileage and power will go down. I think you run out of caster too.
If youll regear and you have auto, I think 5.29s might get you in the 5speed gear range.
95Runner
06-09-2002 08:56 AM
