Please help!! Need pics
I'm an idiot, I know. But I need pics of the idle air control valve just so I know what it looks like and where the crap it is. Still have idle issues and need to fix soon.
I don't have a pic of it, since I have a 22re, but for the 3.0 the Aux air valve that controls the idle is attached to the underside of the throttle body, so you will have to take the throttle body off in order to mess with it. Good luck, I just had to pull mine out as well.
Well, trying to find some pics here about it, I came across a write up of a 3.4 I believe the 3.0 has it in the same area, but don't quote me on it.
https://www.yotatech.com/forums/showthread.php?t=92286
Blgt has it right, FSM is the way to go. There are some links to some pdf form FSM's if you search the forums. The IAC (22re calls it the Aux Air Valve) should have an electrical connection, as the 22re has one. The FSM showed where to adjust it. I haven't seen anything for the 3.0. Hope you find something. Thought about swapping out to a 22re or a 3.4? then all these tips would have fixed your problems!!
FS[SouthEast]: Brand new 26 mm. Downey torsion bars
HiLuxer
09-09-2015 02:43 PM
