Lost cpu fuses
Lost cpu fuses
1990 22re short bed won't start. no spark coil wire to head. pu-coil, coil to dist. wire, coil and igniter are good. measured .020 airgap in dist. and 12vdc at coil's primary. rotor turns. can't find cpu fuse, it isn't in drivers side kick box as indicated in chilton's or Haynes. two questions Anybody have any other ideas where it might be located and would the timing chain slipping cause the computer not to allow firing. thanks eh, me
Scotttekoch
09-28-2015 10:30 PM
