got the yota back togather
well i got my yota back togather but now it only will start with starting flud it has gas the fuel pump is working but it wont start only with starting flud does eneyone have and idele of want it is that is wrong please help me
what repairs did you just finish? You sure you cycled the key enough times to let the fuel pump get the system fully primed back up? Mine took a lot of cycles and crankin before it built enough fuel pressure back up to fire and run pretty.
Do you have the air intake hose hooked up? It wont run unless air is goin thru the airflow meter. If your spraying starting fluid in it it makes me think its not hooked up
Staff
The way your post first started sounded exactly like my problem i fixed yesterday. I just got done trying to do a nice write up on how to fix it starting with easy to harder steps. It is on one of my last few post on my 86 build if you want to try a few of them steps.
Regency
20
01-03-2020 07:43 PM
Johntom240
7
07-13-2015 12:18 AM
