Filter pcv
Filter pcv
Ok I posted this on my build thread but I have been reading adopt about how your pcv valve not being connected or whatever can cause a lean condition I just put a small filter on what I think is the pcv unit the small red filter with blue top.how would I reroute this to where it would be hooked up or is this good the way it is
Sorry for this question but I don't want to f up my motor because I didn't ask
and if that is attached to the intake hose it's also not a good idea whatsoever.
with breather filters your gonna get alot of opinions on this like alot of other mods. Kinda like whether or not to do an EGR delete.
personally I don't like em. too many side effects for something that "looks good"
But then again, Jerry knows I don't care if something looks good as long as it works. lol.
Oh yeah, speaking of keeping a PCV hooked up, that oil pan leak is still holding good, and my PCV and breather lines are hooked back up. lol.
Yes I unhooked mine but for a short time till I fixed a leaking oil pan gasket that was causing a vacuum leak. I'd rather unhook it as the side effects of that out weigh a vacuum leak in my mind.
yeh...function over form.
honestly, i don't know that you accomplished anything good or bad by putting that filter there.
but, PCV, it is not
but, PCV, it is not
