Dual twin stick ?
Ya Andrew your fine... just think of the front case as a reduction unit only. 2wd Lo I guess. Even if your hubs are in when you put it in low your still not in 4wd. I use mine all the time for like backing in the driveway and stuff. A big no no with dual cases though is to push in your clutch and let your truck roll fast down a hill with it in low low. The front shaft is still spinning at the output and stuff starts moving way too fast inside the case. I've heard of two different having their pressure plate explode from spinning too fast doing that.
A twin stick in the rear is particularly helpful if you don't have a selectable locker up front. If you need to turn real sharp in the rocks you can just kick it out of 4wd for a minute so you can actually steer yet keep your reduction. I wish I had one but doing the linkage with my center console would be a nightmare. Just the standard stick took us a whole day to get it to work coming up through the change holder where I have it.
If you leave the hubs unlocked, and put the truck in 4lo, you will essentially have 2 lo. There is almost no point in having twin sticks on a Toyota case.
And don't weld the front, unless you plan on hydro assist or full hydraulic steering. And longs. And a myriad of other upgrades.
#25
But what is the logical purpose?! UNless you are hardcore rock crawling, there really isn't a need to NOT be in 2Low 4x4 hubs locked. Unless you have a spool but really, who drives on FS roads in 2lo with a spool?
Besides, twin sticks don't eliminate the need to lock/unlock the hubs, your hubs would still be locked, the transfer case just won't be engaged.
#26
#27
I got a twin stick in the rear case. Sometimes it has been handy to run the tight turns in 2wd even with the front hubs locked and auto locker. It make some turns a little easier but my t-case doesn't always kick out of 4wd to 2wd as easy as it sounds so thats a PITA. Is it worth it??? Sometimes its cool/useful and other times its just one more thing to remember.
LOL I had a guy one time come up to the driver window and ask if my 4wd was working. oops.
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
primordialbeast117
12-19-2015 12:23 PM
Toys4parts
09-26-2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
