95 4runner lift
Old 07-08-2011, 01:00 AM
conradg_7's Avatar
95 4runner lift
Hey everyone hows it going? neww to the forum,seems great tho!!!
I have 95 4runner and was wanting to do the ball joint spacer in the front and the fj80 coils in the rear,I bought the coils already, still trying order the BJ spacers, also have 33 procomp mud terrains!! i have read up a bit on them on this site and googled it a couple times, I was wondering if any one has like an exact link or any info on that will explain how to do both and if theres any extra hardware that i need? I read some people are cutting things in the front end for the ball joint spacers? soo im just a little confused if im suppose to or not to do this?
thanking you guys in advance
Old 07-08-2011, 05:08 AM
crawyota's Avatar
Location: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
HERE YOU GO , ITS A WHOLE THREAD FOR YOUR MODEL
https://www.yotatech.com/forums/f116...-guide-155339/
Old 07-08-2011, 06:42 AM
87 'runner boosted's Avatar
Ya, true enough, you have to cut the inside bottom of the upper control arm back to fit the spacers, not difficult to do, i bought a 4 1/2" angle grinder from harbour freight for like $20 or something and cut em out. no other hardware needed as far as I know.
Old 07-10-2011, 01:23 PM
conradg_7's Avatar
Thanks a lot for the link crawyota found some good write ups on it ther, I see that you did the same lift, how do you like it? I have the rear coils at my house and just ordered the ball joint spacers..
87 'runner how come you ace to cut for the BJ spacer to fit does it rub if you don't??
thanks a lot guys
Old 07-10-2011, 02:12 PM
No, the ball joint spacer won't fit in there at all unless you cut it. It's really not as hard as you would think, I just made two cuts, got a hammer and long punch and bent it back to fit the spacer.
Old 07-10-2011, 03:45 PM
conradg_7's Avatar
Won't that weakent the arm though?
Old 07-10-2011, 04:34 PM
4Crawler's Avatar
Not really, it is a non-structural piece you are removing, just the outer lip of the control arm:
- http://www.4crawler.com/4x4/ForSale/...owTo.shtml#4WD
On the 2WD pickups, there is no lip there at all.
Another option i trimming is a big issue is to run a lower height spacer, like 1"
- http://www.4crawler.com/4x4/ForSale/...mHeightSpacers
Those will generally fit w/o trimming.
Old 07-11-2011, 07:45 AM
crawyota's Avatar
thanks a lot guys
i like just fine , i still gotta adjust the torsion bars. because the front rubs still since i put the 33x12.50's on.
06-01-2021 01:51 PM
09-04-2015 09:27 AM
akaphilly
07-09-2015 02:18 PM
God's Bounty Hunter
07-08-2015 12:54 PM
skoti89
07-06-2015 07:45 PM
Quick Reply: 95 4runner lift
