How do you remove the rear drums on 2006 Tacoma.
Old 12-26-2007, 07:26 PM
P. Bauer's Avatar
wanted to inspect my drums and shoes on my 2006 Tacoma. Took the wheels off, released parking brake, and hammered a bit, but no luck.
What's the secret? I wish these were disc brakes....
Old 12-26-2007, 07:32 PM
CJM
CJM's Avatar
Two holes on there are for a fine threaded 13mm bolt iirc, they will push the drums off the shoes. You really need to open up the adjuster slot (if its plugged with a cap), get a brake spoon and loosen the adjustment till you can pull them off easy.
Old 12-26-2007, 07:57 PM
P. Bauer's Avatar
two holes?
Removed the rubber plug, didn't see any type of adjustment, other than maybe being able to pry the brake shoe away from the drum.
Where are these -2- holes located? I looked all over the back side of the drum/axle where the rubber plug was located.
thanks for your help.
nick9455649
09-11-2015 05:10 PM
Iceman4193
07-15-2015 04:48 PM
icentropy
07-14-2015 10:23 AM
hangtown88toy
07-10-2015 02:33 PM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: How do you remove the rear drums on 2006 Tacoma.
