Water vs Trans Temp Guages
Old 08-13-2007, 01:52 PM
MUDN4R's Avatar
A friend of mine gave me a autometer water temp guage but since i already have a coolant temp guage i used it as a trans temp guage is there anything wrong with this? about how they read? due to the difference between ATF fluid and coolant? Also whats the transmission temp suppose to be? Mines running around 180 driving and about 200 sitting in the driveway (on a 90+ day and with a front mounted tranny cooler) is it suppose to get that hot?
Old 08-13-2007, 06:05 PM
GenXr's Avatar
What did Autometer say was the difference between their coolant and tranny temp sending units?
Sounds like normal temps to me.
Old 08-13-2007, 06:21 PM
mt_goat's Avatar
I'm using a tranny temp gauge for water and it works fine. That ATF temp sounds fine, mine is about the same.
Old 08-13-2007, 06:31 PM
toy283's Avatar
The gage itself should be identical except for the faceplate. As long as you know what it's for, it's all good.
Old 08-13-2007, 06:40 PM
MUDN4R's Avatar
ok thanks! I thought thats how it was same thing just different face plate!! some guys at work got me questioning it....
Old 08-15-2007, 07:18 AM
rdlsz24's Avatar
All it does it takes the temperature of whatever fluid the thermometer part is installed into. You could use it to take the temperature of your cooked steak if you wanted to.
Rob
Old 08-15-2007, 07:41 AM
97Limited's Avatar
Rob
I second that!! All the temperature Sending units are the same, They all work off resistance.
And Rob great example with the steak!!
Old 07-23-2008, 04:11 PM
Cr@sH's Avatar
im planing on put a trany temp gauge .... where on the tranny do u hook it up to ..
truck is a 1990 pickup 4wd v6 auto
Old 07-23-2008, 04:17 PM
abecedarian's Avatar
kinda like comparing an oral to a rectal thermometer... either one only reads the temperature of the surrounding environment. they are interchangeable (with a good wash ) it's just a matter of knowing where it was stuck and what is the normal temperature in that environment.
200 a/t fluid temp sounds a slight/tad higher than I'd like to see, but isn't bad considering the a/t fluid passes through the radiator.
*sorry for the bad mental image*
Old 07-23-2008, 05:09 PM
mt_goat's Avatar
I put mine in the cooler line before the cooler. I made a place for the probe out of this "T" from Ace Hardware:
Old 07-23-2008, 06:38 PM
GenXr's Avatar
Thanks for those pictures. I was wondering if teflon tape was needed in the tee fitting.
I'm adding a tranny temp gauge to my Isuzu Trooper.
Old 07-23-2008, 07:28 PM
jasond's Avatar
There is a special teflon tape that you are supposed to use with oil, I think that it is yellow instead of white.
Old 07-24-2008, 03:44 AM
mt_goat's Avatar
I didn't know that, thanks Jason.
Old 07-24-2008, 09:05 AM
Cr@sH's Avatar
thanks for the pic ......
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
07-16-2015 06:20 AM
Jonny246
07-12-2015 04:51 AM
Poncho0206
07-10-2015 06:21 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: Water vs Trans Temp Guages
