Water temp sensors.... 22re
Old 10-23-2010, 01:23 PM
87tonkatoy's Avatar
So what is the temp sensor in the thermostat housing go to? the if the ecu water temp is the two wire and cold start is two wire next to it and the gauge sensor is in the center of manifold then what is the one on thermostat housing do?
Old 10-23-2010, 01:30 PM
myyota's Avatar
It has something to do with the a/c, at least that`s what ive always been told.
Old 10-24-2010, 12:52 AM
muddpigg's Avatar
Originally Posted by razed
one temp sensor on front of the manifold pointing at the radiator is for the ECu, one on top of the manifold, between 2&3 is for the gauge, one on the elbow on top of the thermostat is for high-altitude compensation package from what i'm told.
Sounds right or was it for hot starting don't remember. Was also only the 4x4.
the1998sr5
15
07-14-2020 08:35 PM
Jeffreynmandy
07-18-2015 08:26 AM
Jonny246
07-12-2015 04:51 AM
Avenged
07-09-2015 07:55 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Water temp sensors.... 22re
