Valve Ticking
Old 06-01-2010, 12:07 PM
T_F_E's Avatar
Valve Ticking
Hey guys I have done a lot of work diesel motors and old chevy's but nothing on these toyota so take it easy on me. I bought a little 88 pickup with a 22re that was rebuilt 40 thousand miles ago. This truck is maintained great and has a ton of receipts for everything done to it. Problem I have is a valve tick at the furthest back cylinder I believe intake valve, sounds kinda like a cummins that needs adjusting. Are these valves pretty easy to adjust? Does anyone have a procedure for me? Anything else it could be?
Thanks everyone for your time,
Mike
Old 06-01-2010, 12:32 PM
xxxtreme22r's Avatar
pretty common adjustment here. easy too, just like doing a SBC. a small search for a down-loadable FSM (plenty of links posted here) will net you the specs and how to do it.
Old 06-01-2010, 12:33 PM
toyota4x4907's Avatar
Its super easy to do. takes about 30 minutes on the first time doing it. Search here man. Procedures have been mentioned many times before.
BUT!! If it still ticks, don;t get discouraged. These motors tick a lot, even with the valve lash in spec. The injectors are loud and the valves are loud.
And welcome to the addiction
Old 06-01-2010, 12:39 PM
T_F_E's Avatar
Alright guys sounds easy enough ill update back later tonight hopefully! I love this little truck I got 27 mpg on the way back from buying it with a canopy on. I need to replace a cv joint for the 4wd but other than that it should be great!
Old 06-01-2010, 12:50 PM
highonpottery's Avatar
damn, 27mpg w/4wd? i've only gotten that close once with a tail wind and injector cleaner. good luck on the valves
Old 06-01-2010, 12:51 PM
T_F_E's Avatar
Yeah thats what I said, its has stayed over 22 since
LotOMiles
09-14-2015 11:45 PM
ac7822
09-11-2015 08:49 AM
Boomer8404
09-10-2015 09:01 AM
ErikZ1220
09-10-2015 04:53 AM
idadan208
09-07-2015 09:06 AM
Quick Reply: Valve Ticking
