uncoding the differential
Old 11-06-2010, 02:27 PM
yotarover's Avatar
i read 4crawlers write up on the diffrent gearing for the 88 trucks n runners.
to cut it short bad vibrations led me to a dying u-joint (np) but i decided to drop the shafts to see the color codes.
rear-yellow indicating 4.56
front- red-chip on bottom of nut. nut had a flat slant in it
as far as i know nothing has ever been changed on the truck (according to my grand father who bought it brand new)
Old 11-06-2010, 02:31 PM
MudHippy's Avatar
You've approached the problem from the wrong angle. Literally.
You don't need to get down on the ground.
Instead read this.
Staff
DeathCougar's Avatar
Nevermind the color, what is the Axle code on the info plate?
Old 11-06-2010, 02:52 PM
yotarover's Avatar
it was g252 but i wanted to check the color as well shoulda stated that previously , and i already knew about the newbie gear info page. i knew the uj's needed to be replaced so i saw that it's wasn't a waste of time to look anyways sorry
Old 11-06-2010, 03:01 PM
scuba's Avatar
to tripple check.....
http://www.5speedtransmissions.com/d...ear_ratio.html
Old 11-06-2010, 03:29 PM
yotarover's Avatar
Originally Posted by scuba
started to do that then it got colder
Old 11-06-2010, 03:34 PM
yotarover's Avatar
pretty sure by now that both are 4.56 i jsut have to replace my cv shafts (what's causing the clicking noise) and the uj to end to vibration
Old 11-06-2010, 03:39 PM
yotarover's Avatar
btw anybody have an idea what this is for? mines broken
is it even important or can i just block it off and forget about it?
Old 11-06-2010, 03:56 PM
MudHippy's Avatar
I'm fairly certain that's the VSV for the PAIR. Important? Depends, do you need to have the emissions checked by DEQ to register the vehicle legally? If not then no. Go ahead and block it off.
http://personal.utulsa.edu/~nathan-b...20pulsedse.pdf
justdifferentials
Just Differentials
06-13-2022 07:40 PM
justdifferentials
14
06-11-2017 08:36 PM
shooter86314
01-07-2016 07:05 AM
voiddweller
10-02-2015 07:47 AM
Odin
09-26-2015 06:56 PM
Quick Reply: uncoding the differential
