Tranfer case or Axles?
Old 01-16-2007, 06:29 AM
Flygtenstein's Avatar
No, you can unbolt the stock case on the older autos.
That is what the Inchworm deal relies on.
Old 01-16-2007, 08:42 AM
cweich's Avatar
Originally Posted by AH64ID
I think he said he was only worried about offroad performance, in which case xcase gears will be much better than diff gears... this way he can save for gears/lockers... which will run more than xcase gears anyhow...
Fixed... brain fart was all
You are right, i am only looking for offroad use. I welded the rear diff, i left the front open, my wheel base is only 83 inches, so i don not have room for dual xcases. It sounds like the auto t-case is a bear to mess with, so i may be looking at gears in the diff only.
Does anyone make a mini spool for the rear diff?? I don't need a locker will never see the street.
I think my IFS truck will take me any where i will ever want to go. The short wheel base really helps.
Old 01-16-2007, 09:44 AM
Fish Taco's Avatar
Looks like you got a lot of advice so far and I din't read everything so I apologize if I am repeating something someone already said.
Yes, obviously you got that you t-case only effects gearing when you're in 4wd and then in 2wd when you go to a dual setup (although not all 2wd so you can still drive on the road normally). But this does not effect gas mileage or top speed.
To be hauling 35s at any acceptable rate up some hills you need to switch out the gears in your differentials. Some people suggest going really far for this. I disagree. I've accepted that my truck will not be going 75 up hill with 35s on it so I geared down for a higher top speed and better gas mileage to 4.88 gears. I would not suggest going any higher than this because the higher the gear ratio the weaker the gears (unless you go chromolly). 5.29 gears will get torn up quick! Trust me on this. I already tore up my 4.88s.
If this is an off road truck only, I would suggest making the truck absolutely as light as possible (get rid of all the sheet metal, A/C, stereo, back seat, etc.) and go with a 4.10 gear if possible. They are pretty strong still. If you want to keep some weight and some luxuries, go 4.56 or 4.88. Try a calcualtor too to see how close you are getting to your original gas mileage and top speed.
Feel free to contact me and I'll give you some info.
--Megan
Old 01-16-2007, 11:18 AM
Gotta get rid of the rubbish.
Chromoly gears?
You killed one set of 4.88's and now everything else is going to die too?
Why run 4.10's on a trail truck? The necessary premises are implicit and rely on the first part of your argument.
Old 01-16-2007, 11:26 AM
  #25
cweich's Avatar
Chromoly gears?
I have run deep gears before, and never had any troubles, but they have never been in a toyota, is there any truth to breaking the deeper gears??
Old 01-16-2007, 11:31 AM
  #26
Lower ratios have smaller pinions with fewer teeth. That is true.
I have killed one set of 5.29's in my 8" V-6 Toyota rear. That is true.
It had a shoddy wear pattern that likely lead to the break. That is true.
Old 01-16-2007, 05:31 PM
  #27
Staff
DeathCougar's Avatar
But i still think you are missing my point....on the MT trucks, you just undo the 6 or 8 bolts and the case slides right off. On the auto trans trucks, you have to remove more bolts, and gain access to the bolts inside the case, to release it from the tranny. It takes much more effort to remove an AT case, than it does a MT case.
Re-reading my post and yours, I think we are agreeing. Cuase, you can unbolt the case...i know that...it just takes more work, thats all.
Isn't the internet lovely? Even when we agree we disagree lol.
Old 11-04-2009, 04:42 AM
  #28
Master_Yota's Avatar
drop the auto and get a 5speed. huge difference.
Old 02-18-2010, 02:30 PM
  #29
yotaman85's Avatar
let me get this right, the automatic tranny and manual tranny have different transfercases?
Old 02-18-2010, 02:36 PM
  #30
Staff
Sarcasm and 3 month old thread revival duly noted
4x4-runner
04-18-2017 09:08 PM
PNWrider
10-30-2015 08:14 AM
Jcrawl94
10
10-24-2015 04:34 PM
JimiJams
08-07-2015 01:36 PM
priest16
15
08-06-2015 07:43 AM
Quick Reply: Tranfer case or Axles?
