tourqe specs for head bolts?
Old 08-29-2005, 12:20 PM
klslaven's Avatar
Question tourqe specs for head bolts?
I need to know tourqe specs for head bolts, do you need to replace the head bolts or can you reuse them?
Old 08-29-2005, 01:54 PM
87TurboYota's Avatar
Yes, you should replace your head bolts. But I'm not positive on the torque numbers.
Old 08-29-2005, 03:59 PM
jimbo74's Avatar
what engine? if its the 22r its either 58 or 63 -- i forget which
Old 08-29-2005, 08:33 PM
the_4runnin'_beast's Avatar
definitely replace the head bolts. when they are installed, they actually over-torque the head bolts just a little bit. when they do this is stretches the bolts just a little bit to get a good seal between the head and the block. this is on your 96 right?
these r the torque specs for all 96 engines:
2rz-fe and 3rz-fe:
Step 1: 29ft pounds
Step 2: 90 degree turn
Step 3: 90 degree turn
5vz-fe:
Step 1: 27ft pounds
Step 2: 33ft pounds
Step 4: 90 degree turn
1fz-fe:
Step 1: 27ft pounds
Now, there are torque sequences but its hard to explain without actually showing it to you. Make one pass in the correct sequence for each step. I hope this helps. Sorry I can't help you with the sequences! Good luck!
Old 08-29-2005, 08:37 PM
on the 22r it is 53-68ft pounds! got the 3 and the 8 mixed up, but, good pull!
kgcwb44
01-29-2023 10:02 AM
bigjstang
08-25-2021 12:41 AM
dumpster84
04-30-2016 06:03 AM
09-04-2015 09:27 AM
whereAreMyPants
07-22-2015 03:32 AM
Quick Reply: tourqe specs for head bolts?
