tourqe specs for head bolts?
I need to know tourqe specs for head bolts, do you need to replace the head bolts or can you reuse them?
Yes, you should replace your head bolts. But I'm not positive on the torque numbers.
what engine? if its the 22r its either 58 or 63 -- i forget which
definitely replace the head bolts. when they are installed, they actually over-torque the head bolts just a little bit. when they do this is stretches the bolts just a little bit to get a good seal between the head and the block. this is on your 96 right?
these r the torque specs for all 96 engines: 2rz-fe and 3rz-fe: Step 1: 29ft pounds Step 2: 90 degree turn Step 3: 90 degree turn 5vz-fe: Step 1: 27ft pounds Step 2: 33ft pounds Step 3: 90 degree turn Step 4: 90 degree turn 1fz-fe: Step 1: 27ft pounds Step 2: 90 degree turn Step 3: 90 degree turn Now, there are torque sequences but its hard to explain without actually showing it to you. Make one pass in the correct sequence for each step. I hope this helps. Sorry I can't help you with the sequences! Good luck! :great: |
