Temp Gauge
Old 09-03-2006, 08:11 PM
MAXIMUS1968's Avatar
Temp Gauge
Where should the temperature gauge read? I have a 94 Toyota pickup 22re. It is reading only around 1/4 off the cold mark.
I have replaced:
timing chain
water pump
belts
plugs
plug wires
distributor cap
rotor
adjusted timing with the connections jumpered will run correctly only at 1 degree BTDC (should be 5 degree BTDC)
Seafoam treatment (vacuum and fuel)
I was just wandering if this is the correct temperature, i have a very slight mid range rpm stutter when holding the throttle, but i cant feel anything while normal driving. Just curious if the temperature is right if it may cause the air fuel ratio to cause it to do this? Any ideas???
Thanks
Old 09-04-2006, 06:43 AM
bump!!!!!!!!!!
Old 09-04-2006, 08:02 AM
91_4x4runner's Avatar
After about 5 minutes of running (getting to operating temp.), mine shows right about in the center of the guage. After that it doesn't really change between 0 and 100 mph...
Old 09-04-2006, 01:14 PM
dcg9381's Avatar
I don't know how the later trucks are, but there are some indications that the temp gauge is elecrically "dampened".. That is, it sits right in the middle within a specific range of temp and only jumps outside that when overheating or really cool..
Measure the resistance on your temp sender when cold and then when at running temp, I think I've got the specs around somewhere per FSM.
Old 09-04-2006, 02:09 PM
Elton's Avatar
i never really trusted the temp gauge
ashamsuddin
17
01-13-2023 03:17 AM
Jdgarrison
10-01-2015 05:22 PM
bradahman
10-01-2015 09:24 AM
Matthew Perez
09-28-2015 05:43 PM
rmill05
09-27-2015 01:43 PM
Quick Reply: Temp Gauge
