strange whirring noise
#41
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Zuk has a website http://gearinstalls.com/. You can get ahold of him there, or send him a Private Message, he's a member here.
#42
I'm counting down how long it takes Zuk to materialize in this thread......
I can see the mystic cloud of smoke beginning to roll in already......
#43
did that fix it?
i had some noise that came with speed once and it turned out one of my cvs was not disengaging so one side would turn all the gears.
man, after seeing your pics i think im not going to put off changing my diff fluid any longer!
#44
please dont put off changing your dif fluid... its not pretty... also check and clean/install dif breathers regularly because i presume thats what started the blown se3al in the first place... but that was before i found yotatech...
i too am waiting for ZUK to materialize...
as for matt's writeup, here it is...
https://www.yotatech.com/forums/f116...nstall-161405/
just ignore the locker installation part if you arent doing that...
#45
ZUK is best reached at gearinstalls@gmail.com ...
if its after around 7 oclock at night, he'll more than likely get back to you the next day around 10am...
he is a great guy to work with and is very quick at getting the job done...
he will also do a writeuo on your 3rd if you ask him to... heres mine...
http://www.gearinstalls.com/troy.htm
and for anyone who wants to see carnage, i forgot to post the pics of what not changing your gear oil and not cleaning your breathers will do...
these are all about the size of my pinky and a lil smaller...
and the carnage...
and the carnage...
#46
Whirring noise from inside the cab
I know this thread is old, but I need help diagnosing something in my truck. I can't post new thread, so here I am.
Truck is a 97 4Runner, V6 SR5 4WD. Bought it new in '96 and never really had any problem with it. It has 218K miles on it. Performed regular maintenance on it.
I took it to Jiffy Lube and had them change the oil with high mileage 10W30. Also had them perform the Rear Differential Service.
I started having a whirring noise when I start the truck that changes with rpm.
I thought it was valve tapping. You can hardly hear it when you open the hood, but inside the truck, you can definitely hear it and it is really annoying me. You can hear it even when the truck is not in gear and at a stand still.
I have oil leaking out of the headers for a while, so I took it to the dealership and they fixed the gasket and the leak and they told me that the truck sounded normal for a high mileage truck. They also told me that it is not valve tapping. The job cost me $700+. I am glad they fixed the leak, but I could have done it myself, but I just don't have the time.
So, could it be that Jiffy Lube messed up and not put enough differetial fluid?
Could it be the fan clutch? Please help.
#48
Not sure this is the right place to be hi-jacking a thread. But I'll bite
So the truck only makes this noise while moving??
Why/How did you inspect under the hood if that is the case?
#49
zytra
01-24-2019 03:16 PM
zombie_barbarossa
10-02-2015 10:54 PM
