Strange Starting Issue
Old 10-28-2009, 10:10 PM
GodwinAustin's Avatar
I searched and didnt find what I was looking for. Just got below freezing out here in colorado and went to start the truck after it had been sitting for a while, turned the key - lights, power, but nothing from the starter, no cranking sound whatsoever. Nothing. Not even a click.
Tried it a few more times, still nothing. No sound whatsoever.
Waited, tried again, and it started right up perfectly.
Ideas?
Old 10-28-2009, 10:14 PM
Yotapowa's Avatar
Tap it with a hammer? Or maybe there is a bad connection somewhere, it never hurts to check those out as well
Old 10-28-2009, 11:37 PM
limon32's Avatar
First thing that should be done is remove and clean the power connections like the terminals and ground points.
I have seen lots of terminals that "Look pretty clean" but are corroded between the post and inside of the terminal. Also a loose terminal can do the same thing.
Check those items first, they are free and easy.
Old 10-28-2009, 11:46 PM
Jory121's Avatar
simple....bad starter
Old 10-29-2009, 06:54 PM
mtnfreak's Avatar
If everything but changing the starter fails, follow Roger's advice: http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
coryc85
09-09-2015 06:24 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Strange Starting Issue
