Steering Gearbox Leak
Old 10-23-2006, 10:20 AM
DOT3's Avatar
Anybody have any idea of where I can get the seal for the pitman shaft. This is the lower seal on the gearbox where the pitman arm connects to the gearbox. Dealer can't get it.
1987 2WD 4 CYL Power Steering 5 spd
Thanks
Old 10-23-2006, 10:32 AM
waskillywabbit's Avatar
I find that hard to believe that the dealer can't get it. I can believe they don't want to look for it.
Try "strap22" on here as he deals in Toyota parts and is an all around nice helpful guy.
Good luck.
Old 10-23-2006, 10:39 AM
DOT3's Avatar
Just came from the dealer and he ordered the seal for me twice and it was the wrong size. We could not figure why.
The seal I need is OD 1.5" ID 1.188" (shaft OD) or NOK AG8095E. NAPA does not have it either.
Old 10-23-2006, 10:41 AM
I assume your parts dealer person is searching using your VIN#? Is this a stock truck?
Old 10-23-2006, 10:47 AM
DOT3's Avatar
Yes
JT4RN 70D2H 0034277
I've found a 1.125 ID. Will that seal it?
Old 10-24-2006, 11:16 AM
DOT3's Avatar
Bump
Somebody has to know where one of these seals are!
1.5" OD seal on a 1.188" OD Shaft.
Old 10-24-2006, 11:47 AM
runethechamp's Avatar
Check this link:
http://www.trademotion.com/partlocat...13&catalogid=1
Are you talking about item number 13 here?
Also see page 4 here:
http://personal.utulsa.edu/~nathan-b...ng/13gearh.pdf
Old 10-24-2006, 04:06 PM
DOT3's Avatar
Yes, Item 13 sector shaft seal.
My dealer ordered the above item 13 twice and it's the wrong ID and OD.
Old 10-24-2006, 08:23 PM
Are your steering box and pitman arm original?
Or maybe there was a change in dimensions sometime in 87?
Old 10-25-2006, 05:02 AM
DOT3's Avatar
I'm the original owner and the gearbox is original.
Last night, I went ahead and put the 1.125" seal on. It was a tight fit but it seems to be sealing.
The 1.125" ID seal is the largest ID seal you can get with the 1.5" OD. The seal makers would make the larger ID but the min orders were large (200 min).
I don't understand why the Toyota seal was the wrong size. We checked the part number for 1986 trucks and it was the same as 1987. My production date is 10/1986.
Old 06-15-2020, 10:39 PM
Harry Moon's Avatar
Did you find it??
I have the exact same problem
order 6 seals so far, all not right
i need the 1.5” n they are all coming in too big
Old 06-16-2020, 02:20 AM
wallytoo's Avatar
after 14 years, one would hope so!
The following users liked this post:
Harry Moon (06-16-2020)
delmert
09-30-2015 04:34 PM
Up&Down
08-11-2015 10:04 AM
gillesdetrail
08-03-2015 04:43 PM
bobpat
08-01-2015 09:25 PM
gmonnie123
07-26-2015 02:44 PM
Quick Reply: Steering Gearbox Leak
