shocks?
Old 06-30-2013, 08:30 PM
yotaboy423's Avatar
shocks?
on my 86 4x4, stock suspension, i am thinking about replacing the front shocks. is there a way test them to see if they need to be replaced?
Old 06-30-2013, 08:36 PM
yotaboy423's Avatar
and i do decide to replace them what brand and where should i get them? i am not gonna drop a ton of cash on them either so best for the buck would be nice.
thanks
Old 06-30-2013, 08:49 PM
RSR
RSR's Avatar
IMO, Bilstein's are the best shocks. But they're expensive. Ranchos are really soft. KYB's are prob your best *cheap* shock.
Old 06-30-2013, 08:57 PM
RSR
RSR's Avatar
Check if bad on the truck:
And off the truck:
*Basically, you bounce with a solid push the respective corner of your vehicle and if bounces more than once or twice, your shock is bad.
Old 06-30-2013, 09:46 PM
yotaboy423's Avatar
Ok thanks, my shocks aren't as bad as I thought they would be then.
I looked at bilsteins, the ones that would fit.my truck are like 70 bucks a POP but i can do that if nesasary.
Where can I get rubber bushings for the bottom connection on the front shocks? Mine are pretty well gone
Old 07-01-2013, 05:12 AM
JohnnyCanuck's Avatar
they usually come with new shocks, I've seen them at NAPA sometimes if you are just looking for the bushings.
ladybugRC
458
08-21-2020 10:41 AM
ZGjethro
06-07-2017 11:04 PM
dirk89
10-01-2015 05:15 PM
ktm192k
10-01-2015 08:47 AM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: shocks?
