screaching noise when i let out the clutch?
Old 02-01-2012, 01:27 PM
Young Guy's Avatar
Angry screaching noise when i let out the clutch?
so when i apply the gas and let out the clutch from a stop into first gear there is a screatching noise like something is slipping? So I replaced the clutch last weekend and ITS STILL THERE! So could it be from me not refinishing the pressure plate? or could my throttle bearing be adjusted wrong?
Please help! This is very aggravating.
Old 02-01-2012, 05:58 PM
Jkelley429's Avatar
is this only in first gear? if it is then its probably in the tranny. if not then it may be something else. more details will definitely help. you will find your answer on this site.
Old 02-01-2012, 07:29 PM
Young Guy's Avatar
It is only in first gear, that is correct. If you guys have any other ideas but need more info than tell me what im not including, but as far as im concerned, the tranny sounds like a great place to start because that makes a lot of sense.
Old 02-05-2012, 09:12 PM
MADMAXJE's Avatar
did you get your flywheel resurfaced ?
Old 03-08-2012, 09:07 PM
Young Guy's Avatar
So an update on my issue here, i'm still toying with different ideas as to what it could be and it seems to me that it isnt my tranny because my tranny itelf feels very solid, for example the gears are tight and comfortable to shift between, its just the initiation of power that is not "right" if you will. And in response to Madmaxje, i did not resurface the fly wheel because there didnt appear to be any discoloration or imperfections to it as far as i could see, but agian this was being done in a shop where who knows how accurate my "guestimate" actually is. So im inclined to think that that is the source of my issue because thats the only thing that has remained the same between before and after i replaced the clutch. Either that, or is it the fact that i used a Napa manufactured clutch instead of say a Marlincrawler HD clutch? I'm just spit balling and i know you guys can only help so much without being able to get ur hands on what im doing.
Old 03-08-2012, 09:22 PM
Outsane's Avatar
Did you replace the pilot and throw out bearings when you did the clutch?
Old 03-08-2012, 09:34 PM
Young Guy's Avatar
I'm not sure,
http://www.napaonline.com/Catalog/Ca...(P_RecType%3aA)
This is the kit i used, and it says "all necessary pilots and release bearing" So if the release bearing is the throw bearing then yes. If not then i doubt it.
I apologize for the uncertainty. This was around September when we changed the clutch (Me and my dad) but since then i have done all my own work lol So considering he was the one with most the know how he "took car of it"
Unfortunately i am left with this issue that i have to figure out and fix on my own... funny how that works.
Old 03-08-2012, 10:43 PM
thatsmyYOTA89's Avatar
yes release and throwout bearing are indeed the same thing.
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
lmobeats18
08-28-2015 04:57 PM
Dakotaneu
08-15-2015 07:24 AM
norcal98
08-10-2015 06:20 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: screaching noise when i let out the clutch?
