Running Wires from Bed to cab...(Searched)
Tomorrow I am hooking up some ProComp 130 Watt lights on my truck. I am mounting them on the roll bar.
The wires obviously have to go from the lights to the cab where I can hook them up to the battery. Is there a good location to run the wires from the bed of the truck to the cab/dashboard area?
Should I just run the wire under the truck? I am considering drilling a hole in the bed then running it under the cab floor board then drilling another hole and then running wires up to the dash...
Any Ideas??? Any Suggestions?
Jake
Jake
Under the carpet in the cab there are some plastic drain plugs (4) two on the drivers side and two on the passenger sde, you can runwire through them. In fact the harness for the fuel pump runs though the floor just follow that.
Originally Posted by Boaz
thanks lock I will look for the fuel pump relay!
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
