Running rough under load
Old 02-05-2013, 05:04 PM
twr0110's Avatar
Have replaced wires,plugs,cap and rotor. New TPS.O2 sensor. Idle is ok. Cannot set timing correctly, runs worse. Anything past partial throttle doesn't want to run unless you back off or floor it. 2 days in local shop, they don't have a clue. 89 toyota dlx 4x4. 22 re
Old 02-05-2013, 05:26 PM
bone collector's Avatar
First off...what motor and truck?? second... why cant you set the timing correctly?
Old 02-05-2013, 05:57 PM
twr0110's Avatar
Sorry. 89 toyota dlx 22 re. When the timing is set correctly won't stay running
Old 02-05-2013, 05:59 PM
twr0110's Avatar
Also a 4x3
Old 02-05-2013, 06:03 PM
4x3??? lol anywho... at what degree is it set when it does stay running??? any codes??
Old 02-05-2013, 06:08 PM
BamaYota1's Avatar
Why was it in the shop in the first place? Did the problem start out of the blue?
Old 02-05-2013, 07:22 PM
twr0110's Avatar
Set to spec I assume. Went into shop because of this issue. Started about a month ago and got progressively worse.
Old 02-05-2013, 07:25 PM
twr0110's Avatar
Went into shop for this issue. This has been a project truck for me and my dad. We have slowly replaced its over time. Really came out of nowhere. We have tried everything we knew, not that we know a lot. So we took to a friends shop
Old 02-05-2013, 07:28 PM
twr0110's Avatar
The shop didn't tell us if there where any codes. They checked some things. Replaced the TPS that I put in and that didn't do anything either. They told us to take it to toyota.
Old 02-06-2013, 02:47 AM
My guess is you have a vacuum leak somewhere. or a faulty afm, or an air idle control valve. it could be a lot of things. check for codes and start from there. Get the truck home, download a fsm (search for one on this site) then start going over the truck. Welcome to the "project" part of owning a project truck... lol
Old 02-06-2013, 06:46 AM
twr0110's Avatar
Thanks for your input. At dealer now for a diag. And then I will go from there
Old 02-06-2013, 04:40 PM
ummmm... question... Why are you on here asking for help with diagnosis if your just going to move your truck from shop to shop??? Just curious.....
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
chukarhunt
12-08-2019 11:39 AM
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
Quick Reply: Running rough under load
