Replacement Of Head With Pictures
Old 09-29-2009, 05:06 PM
  #101
BLKNBLU's Avatar
Well my '86 only uses 1 of the 3. The others are plugged.
The one that is used snakes around to the VSV for the AC system.
Even in the online '93 manual it only shows 2 being used.
Fed and Can...
http://personal.utulsa.edu/~nathan-b...14layoutan.pdf
...and Cali
http://personal.utulsa.edu/~nathan-b...ne/15layou.pdf
Hope that helps. Good luck.
Old 09-30-2009, 05:24 AM
  #102
Lumpy's Avatar
Mine (92) only uses 2 of them one is capped off. Are you sure you're just not missing a cap?
Old 10-01-2009, 06:26 AM
  #103
partypeepers's Avatar
ok yea its caped off to.. ok i have another question. will the top speed of my truck be reduced if i have size 33.5 tires? along with a camper and smitty bumpers? look at my profile picture its what it looks like, cause it seems like it can only go up to 65 mph,
Old 10-03-2009, 05:18 AM
  #104
92 TOY's Avatar
Originally Posted by partypeepers
Is this a pic of the block with the GASKET OFF??
Do you have a picture from BEFORE you took the gasket off??
How about crossing over to my thread (see the green text at the bottom of this post) and see what you think.
I see oil in your head-bolt holes similar to mine.
You left your block in right?? If you did, what did you do to the holes to make sure they were clean (IE: how did you get that oil out of them?
Old 10-04-2009, 01:35 AM
  #105
Hurricane's Avatar
Be sure to replace ALL gaskets that you break into with new ones, I can not tell you how many people I have seen have major problems by trying to recycle a $15 intake manifold gasket or even burn a valve from a bad gasket.
Old 10-04-2009, 07:35 PM
  #106
pruney81's Avatar
I had an 87 4Runner with 220K miles and 31X10.5 mud tires and I topped out at about 70 mph on a good day
I think that was partly because the motor was old and tired coupled with the larger tires and maybe the speedo was off a bit as well because of the tire size
So, in your case with 33's 65 doesn't sound too bad
That said, my 90 4WD with 235X75X15's and a heavy cap gets up to 75-80 no problem and I think it would easily go faster I just haven't pushed it.
Old 10-10-2009, 04:45 PM
  #107
tj884Rdlx's Avatar
with my 33s i cannot go over 75 unless its a downhill grade. going uphill on an interstate, from 75, my truck will slow to under 70 - while floored in 4th. i try to shift to keep the rpms just above 3k. that seems to be where my power is. i rarely pass 4k rpms.
to correct this, i must get 4.88s or 5.29 gears. so i just take it easy on 'er until i can print the money to make that happen.
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
elwood73
07-05-2015 07:07 AM
Quick Reply: Replacement Of Head With Pictures
