Radiator Fan stopped working.
Drove 30 miles, turned of the truck for 15 min, started again, went less than a mile and it stopped.
Loud squealing noise, and smoke, the fan is not spinning. I can spin it by hand.
What's the fix?
The problem is that broken belt. I dropped it of at the mechanic. How much damage should I expect? Should I get all the belts replaced?
What's the fix?
Limped to the mechanic and left it there. You can see that the belt is broken. What can I expect to pay?
Replace other belts?
I knew I shouldn't have been asking around for a new truck - this one got mad.
You may get lucky and only need belts or a fan clutch. Worse case would be (and I know this because im waiting on mine to come from EBAY as we speak) You would need a fan bracket, A.K.A. fake (false)water pump bracket. Thanks to some help from some good guys here, I didnt pay the dealer $700.00 for just the fan bracket (less than 80.00 on EBAY). If you need the fan bracket, yours being a 92 V6 I think your fan bracket has a spring instead of the 93-95 Hydraulic tensioner. Correct me if im wrong here guys.Not a difficult fix if you have a 10MM and a 12MM socket, trust me.
the1998sr5
15
07-14-2020 08:35 PM
