Problems w/ E-brake handle retracting..
Old 10-16-2006, 09:18 AM
GodAmYota's Avatar
It's not so much that the handle won't retract. I just got the truck this weekend, and the E-brake handle wasn't in the tube under the dashboard.
I tried sliding, twisting, spinning, and no luck, like the 2 little locking mechanisms don't agree.
Do I need to remove the entire tube assy. and reconnect the cable that way, or is there another way?
TIA
JT
Old 10-16-2006, 09:59 AM
gregbreakseverything's Avatar
On my truck old truck, the whole assembly underneath the truck was rusted and seized. The only way I could get my handle back in and the light to go off was to yank on the e-brake cable just underneath the passenger side of the truck.
Old 10-16-2006, 10:35 AM
GodAmYota's Avatar
I guess I should have clarified..
The actual handle, in the cab, under the dash, is completely out of the tube. The cable end, that goes to the E-brakes is down by the firewall, in the Tube, that houses/locks the e-brake mechanism.. I can't get the "charge handle," back into the tube, to reconnect the cable end..
Thanks though, I'll check the rest of the assy. while I'm under there..
JT
Old 10-16-2006, 03:04 PM
Nic
Nic's Avatar
I had the same problem when I replaced my broken e-brake cable. I took mine out thinking it would be easy to put back in. For the life of me, I could not figure out why it would not go back in. If you look inside the tube with a flashlight (if it is like mine), there are two tabs that move up and down. If I remember correctly, both tabs must be pushed up and away from one another in order to get the handle back in. Kind of like a pair of wings.
Maybe that will get you on the right track.
Old 10-16-2006, 05:34 PM
GodAmYota's Avatar
Sweet, I'll give it a try.. I hate parking the truck, knowing the gear is the only thing holding it still..
JT
JookUpVandetti
09-30-2015 08:58 AM
Mike Maiato
08-28-2015 02:35 AM
Yotadawgjr
10
08-23-2015 10:51 AM
Duppie007
08-20-2015 04:39 AM
User 051420
34
03-31-2004 01:19 PM
Quick Reply: Problems w/ E-brake handle retracting..
