Opinions: 22rte mpg & gearing
I ran 4.10s on 31s on my turbo truck, I barely noticed a difference over stock. In fact, it ran better up hills. A urbocharger's otuput is dependent on engine load. With larger tires, you have a taller effective gear, putting more load on your motor, which actually causes the turbo to spool FASTER than with shorter gears.
Now 4.10s, 33s, and non-turbo motor, that's a dog.
If you're looking for a Supra LSD, you might as well take the 4.30 gear set out of a non-turbo Supra while you're at it, and get the gears if you want to go shorter.
yourrealdad
07-29-2015 11:08 AM
coffey50
07-28-2015 10:55 AM
