Oil pressure sender help, 89 pickup.
Old 06-04-2012, 08:45 PM
beensoko's Avatar
Hey guys, I have a 91 4x4 pickup with a manual transmission. I recently swapped a better condition 89 22re and pulled the existing 22re.
The engine purrs but I cant get the oil pressure sender working!! The new engine came with a oil pressure switch, I removed it and installed the old oil pressure sensor/sender; resulting in the needle not moving in off/low position.
I rewired from the quick connect and purchased a new oil pressure sensor for a 91 pickup (my error, should have been a 89). Anyways same error, needle stays parked in off position.
When i ground the wire to the base of the sensor the needle jumps to full pressure indicating the wiring is good.
Using a multimeter and checking the resistance between the sensor connection and battery negative terminal shows open circuits on both sensor.
This is driving me crazy, any ideas?????
Old 06-04-2012, 10:59 PM
wyoming9's Avatar
Wink
Did you use some sort of sealer on the threads to the block.
Your most likely not getting a good ground hence when you ground the sensor base it now reads like it should.:wabbit2:
bigjstang
08-25-2021 12:41 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: Oil pressure sender help, 89 pickup.
