Is my engine dieing ?
Old 04-26-2010, 11:36 PM
1993hiluxsr5's Avatar
Originally Posted by hunter4runner
where are you that you have a 2.8D ?
what ? :S it a 2.8 Diesil 4cylinder
Old 04-27-2010, 12:23 AM
totally a bro
Staff
vital22re's Avatar
3L is the block id. Its what the rest of the world had while we got the 22re and the 3vz
Old 04-27-2010, 12:28 AM
Originally Posted by awdjunkies
93Hilux where are you from? or better said, what country are you in? I thought the D in your 2.8D stood for Diesel which in turn means Turbo Diesel correct? unless you are in a different country which is probably why you are calling it a Hilux.
im in australia, and it is definatly not a turbo diesel its just a simple 2.8 it needs a turbo like no tomorow, but i really cant afford to buy one, then a new exhaust system and everything else :-/
Old 04-27-2010, 12:31 AM
i have a question tho guys, my truck has a snorkel on it and its a big old thing, but just after the intake at the top is a big metal ring that has a really tiny hole in it, about 1inch diameter, could this be choking my engine of air ? becuase i thought its size was a bit off for the air demand of a 2.8, i had thought about making it bigger but im not sure if it would change the frequency of the intake and give even less power
Old 04-27-2010, 12:39 AM
  #25
totally a bro
Staff
vital22re's Avatar
could you take a picture? if you think it may be a culprit, try driving with it off.
Old 04-27-2010, 12:43 AM
  #26
yeah i can get a picture, but it'll have to wait until tomorow as its night here, and yeah good point, ill have to give it a go and see if it makes a difference and also my truck gives out a fair amount of black smoke, not a huge amount, but a bit when under full throttle and heavy load, is that just what it does or is it unburnt fuel ?
Old 04-27-2010, 12:44 AM
  #27
totally a bro
Staff
vital22re's Avatar
if its smoking then its rich. Need more air!! but a little smoke will be there no matter under load/heavy load.
Old 04-27-2010, 12:45 AM
  #28
if its smoking then its rich. Need more air!! but a little smoke will be there no matter.
ahh well if it needs more air then that metal ring might solve 2 problems, power and smoke
Old 04-27-2010, 01:07 AM
  #29
totally a bro
Staff
vital22re's Avatar
I hope it does solve your problems.
Old 04-27-2010, 01:31 AM
  #30
me too, thanks for all the quick replys.
Old 04-27-2010, 01:46 AM
  #31
totally a bro
Staff
vital22re's Avatar
well i'm just off from work and usually kill an hour or two before i sleep. Fyi its 2:46am in kirkland, washington USA
Old 04-27-2010, 01:58 AM
  #32
damn, why you on so late, do you work nights or something ?
Old 04-28-2010, 02:10 AM
  #33
Alright, i took the metal ring off my snorkle and it didnt seem to do anything, there is a very very small increase in throttle response/power but its nothing much so now im pretty much out of ideas :-/
Old 12-05-2013, 02:10 AM
  #34
Texy-92 hilux's Avatar
I have a potential head gasket problem in my 92 hilux. When I bought it had heavy 33" boggers on it and had trouble turning them. couldn't go faster than 85 km on highway. put lighter all season 31" tires and it helped a lot. Hoping a new head gasket will help even more. Try getting a compression test and a leak down test and that could help determine head gasket problems.
Charecter1
11-06-2023 10:08 AM
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
Colington
03-08-2020 09:51 AM
Alex Bessinger
08-31-2015 09:17 AM
Quick Reply: Is my engine dieing ?
